CM 6.0 - Meridian Integration (ISDN Layer 2 Down)
Sep 8th, 2008
Hi All
:) we really fed up from this setup, I hope somebody can give a hand here.
We have Nortel CS1000 that we want to integrate with CUCM 6.0.
We are using 3845 Router
The Configuration made as below.
Current configuration : 1682 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
card type e1 1 1
no aaa new-model
clock timezone Kuwait 3
network-clock-participate slot 1
ip cef
no ip domain lookup
isdn switch-type primary-qsig
voice-card 0
no dspfarm
controller E1 1/0
pri-group timeslots 1-31
controller E1 1/1
interface GigabitEthernet0/0
ip address 192.168.33.100 255.255.255.0
duplex auto
speed auto
media-type rj45
no keepalive
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
media-type rj45
no keepalive
interface Serial1/0:15
no ip address
encapsulation hdlc
isdn timer T310 120000
isdn protocol-emulate network
isdn incoming-voice voice
ip http server
no ip http secure-server
control-plane
voice-port 1/0:15
dial-peer voice 1 pots
tone ringback alert-no-PI
destination-pattern .T
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
password cisco
login
scheduler allocate 20000 1000
end
Router#sh isdn status
Global ISDN Switchtype = primary-qsig
ISDN Serial1/0:15 interface
dsl 0, interface ISDN Switchtype = primary-qsig
**** Slave side configuration ****
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = AWAITING_ESTABLISHMENT
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0xFFFF7FFF
Number of L2 Discards = 0, L2 Session ID = 80
Total Allocated ISDN CCBs = 0
Router#sh controllers e1 1/0
E1 1/0 is up.
Applique type is Channelized E1 - balanced
No alarms detected.
alarm-trigger is not set
Version info Firmware: 20060711, FPGA: 255, spm_count = 0
Framing is CRC4, Line Code is HDB3, Clock Source is Line.
Current port master clock:recovered from controller 1/0
Data in current interval (264 seconds elapsed):
Router#debug isdn standard
*Sep 8 10:08:39.555: ISDN Se1/0:15 EVENT: Pri_Activate_L2: sending NL_EST_REQ
*Sep 8 10:08:43.555: ISDN Se1/0:15 Q931: Ux_DLRelInd: DL_REL_IND received from L2
*Sep 8 10:08:43.555: ISDN Se1/0:15 EVENT: CCPRI_Go: received NL_REL_IND
*Sep 8 10:08:48.555: ISDN Se1/0:15 EVENT: Pri_Activate_L2: sending NL_EST_REQ
*Sep 8 10:08:52.555: ISDN Se1/0:15 Q931: Ux_DLRelInd: DL_REL_IND received from L2
*Sep 8 10:08:52.555: ISDN Se1/0:15 EVENT: CCPRI_Go: received NL_REL_IND
Router#debug isdn q921
*Sep 8 10:10:36.555: ISDN Se1/0:15 Q921: L2_EstablishDataLink: sending SABME
*Sep 8 10:10:36.555: ISDN Se1/0:15 Q921: User TX -> SABMEp sapi=0 tei=0
*Sep 8 10:10:37.555: ISDN Se1/0:15 Q921: User TX -> SABMEp sapi=0 tei=0
*Sep 8 10:10:38.555: ISDN Se1/0:15 Q921: User TX -> SABMEp sapi=0 tei=0
*Sep 8 10:10:39.555: ISDN Se1/0:15 Q921: User TX -> SABMEp sapi=0 tei=0
*Sep 8 10:10:45.555: ISDN Se1/0:15 Q921: L2_EstablishDataLink: sending SABME
Appreciate any help.
