WIFI A.P. Bandwidth per client
Answered Question
Sep 8th, 2008
hi ,
do you know a cisco product that can do the folowing :
an outdoor access point with qos capability to limit bandwidth per client
Overall Rating: 4 (2 ratings)
Robert Rowland III Thu, 09/11/2008 - 05:48
According to cisco documentation current products do this just fine. I believe the use of the word "guest" here does not only refer to the "guest vlan w/lobby ambassador" concept.
• Manage Bandwidth by Guest User Type. In addition to tailoring user portals, Version 4.2 enables administrators to customize bandwidth privileges for specific user groups. Administrators may easily restrict bandwidth to low-priority groups such as short-term consultants, for instance, while assigning higher throughput to groups requiring fast connectivity to resources such as enterprise resource planning (ERP) systems or research portals. When a guest logs into the network, the WLAN controller automatically enforces the bandwidth policies assigned to the particular guest's user group. The policies are applied on downstream traffic, helping to ensure that administrators are able to control network resources efficiently.
jeff.kish Thu, 09/11/2008 - 07:02
  • Silver, 250 points or more
I don't think there's a Cisco product that can do QoS per client. Any/all QoS is determined by SSIDs/VLANs.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
