Anyway to say wich IP is generating traffic in the router
Answered Question
Sep 8th, 2008
Does anyone know someway to see in the router wich IP address is generating more traffic?
With nbar I can see wich protocol is loading the link but not the IP who is doing this.
I would like to know if I can do that with only the router cli, with no external server.
Correct Answer by simontibbitts about 8 years 4 months ago
Hi.
You can use Netflow for the ingress or IP accounting for checking egress
Netflow:
interface FastEthernet0/0
ip flow ingress
show ip cache flow
IP Accounting:
ip accounting
show ip accounting
Correct Answer by spremkumar about 8 years 4 months ago
you can make use of netflow to check the same.
you need to enable ip route-cache flow under the ethernet interface and can check the traffic pattern using show ip cache flow command.
The output will give u a clear idea about the source/destination port/ip address packet counts to identify the utilization pattern.
regds
Overall Rating: 5 (2 ratings)
Correct Answer
spremkumar Mon, 09/08/2008 - 04:04
regds
Correct Answer
simontibbitts Mon, 09/08/2008 - 04:12
Hi.
Netflow:
ip flow ingress
show ip cache flow
IP Accounting:
ip accounting
show ip accounting
