TAPS on CUCM5.X, 6.X
Sep 8th, 2008
I need to use TAPS for a roll out but unlike 4.x which I`ve used it on before, TAPS is windows and CUCM is not- Has any one used TAP`s in a 6.X rollout and how. Do I need to install a new Cisco Windows server and point the CTI RP to it. On 4.x, I co-located the CRS application on the Pub as well - what is needed on 6.x thanks
Chris Deren Mon, 09/08/2008 - 05:46
Exactly, you need a separate dedicated server for CRS running TAPS running Windows.
HTH,
Chris
believ1 Sun, 01/11/2009 - 04:37
Hi all,
If I want to use TAPS on a CCM6 or higher, I'll need UCCX5 and higher. Does anybody have experience running this in VMWARE? I'd be very interested on how it has to be done...
Thanks in advance!
Lieven
htluo Sun, 01/11/2009 - 08:38
You need to install "Cico OS 2003" on VMware first. Then everything should run well.
