Configure domain name on cisco LAP
Sep 8th, 2008
Hi!
We've 36 cisco lightweight access-points. After typing "show cdp neighbours" on switch they all are connected, I see:
Port Device-ID Port-ID Platform
1/1 kv-po-4ap10.cisco.com FastEthernet0 cisco AIR-AP1242AG-E-K9
1/3 kv-po-4ap12.cisco.com FastEthernet0 cisco AIR-AP1242AG-E-K9
1/9 kv-po-4ap15.cisco.com FastEthernet0 cisco AIR-AP1242AG-E-K9
1/15 kv-po-4ap9.cisco.com FastEthernet0 cisco AIR-AP1242AG-E-K9
1/17 kv-po-4ap6.cisco.com FastEthernet0 cisco AIR-AP1242AG-E-K9
1/18 kv-po-4ap11.cisco.com FastEthernet0 cisco AIR-AP1242AG-E-K9
1/19 kv-po-4ap5.cisco.com FastEthernet0 cisco AIR-AP1242AG-E-K9
1/21 kv-po-4ap4.cisco.com FastEthernet0 cisco AIR-AP1242AG-E-K9
1/23 kv-po-4ap3.cisco.com FastEthernet0 cisco AIR-AP1242AG-E-K9
1/25 kv-po-4ap1.cisco.com FastEthernet0 cisco AIR-AP1242AG-E-K9
1/27 kv-po-4ap7.cisco.com FastEthernet0 cisco AIR-AP1242AG-E-K9
1/29 kv-po-4ap8.cisco.com FastEthernet0 cisco AIR-AP1242AG-E-K9
How can I change domain name from cisco.com to my local domain?
Also there is a problem to configure domain server IP address on LAP and controller.
Any ideas will be greatly appreciated!
Scott Fella Mon, 09/08/2008 - 17:17
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
The ap's will get the local domain from DHCP. Set it up on your dhcp server and that should do it for you.
vladskuba Mon, 09/08/2008 - 22:53
And there is no way to configure it statically?
I think that dynamic configuration such type of devices is not a best way, because it can make troubles in situation of dhcp server mailfunction or smth like this.
vladskuba Mon, 09/08/2008 - 23:10
I've tried to issue controller command "config ap static-IP add domain all ".
But still in AP config I don't see any changes.
Scott Fella Tue, 09/09/2008 - 04:20
  • Hall of Fame,
    2017 Wireless
Well since you have static ip on the LAP's that command should work. What error do you get when you try to enter the command. Did you reboot the ap after initiating that command?
vladskuba Tue, 09/09/2008 - 05:09
The most interesting that I don't get any errors.
When I'm doing ssh on AP, I see this:
kv-po-3ap8#sh run
Current configuration : 17268 bytes
version 12.4
no service pad
no service timestamps log uptime
service password-encryption
hostname kv-po-3ap8
enable secret 5 ***
aaa new-model
aaa authentication login default local
aaa session-id common
ip domain name cisco.com
ip name-server 172.20.1.23
power inline negotiation prestandard source
username admin secret 5 *
ip ssh version 2
interface Dot11Radio0
no ip route-cache
interface Dot11Radio1
no ip route-cache
shutdown
interface FastEthernet0
ip address 172.20.201.206 255.255.255.0
no ip route-cache
duplex auto
speed auto
ip default-gateway 172.20.201.1
logging trap errors
logging origin-id string AP:001d.a1cd.3ee6
logging snmp-trap notifications
logging snmp-trap informational
logging snmp-trap debugging
logging 172.20.1.20
control-plane
line con 0
line vty 0 4
transport input ssh
line vty 5 15
transport input ssh
end
but on the controller:
Cisco AP Identifier.............................. 35
Cisco AP Name.................................... kv-po-3ap8
Country code..................................... UA - Ukraine
Regulatory Domain allowed by Country............. 802.11bg:-E 802.11a:-E
AP Country code.................................. UA - Ukraine
AP Regulatory Domain............................. 802.11bg:-E 802.11a:-E
Switch Port Number .............................. 1
MAC Address...................................... 00:1d:a1:cd:3e:e6
IP Address Configuration......................... Static IP assigned
IP Address....................................... 172.20.201.206
IP NetMask....................................... 255.255.255.0
Gateway IP Addr.................................. 172.20.201.1
Domain...........................................
Name Server...................................... 172.20.1.23
Telnet State..................................... Disabled
Ssh State........................................ Disabled
Cisco AP Location................................
Cisco AP Group Name.............................. none
Primary Cisco Switch Name........................ *****
Primary Cisco Switch IP Address.................. Not Configured
Secondary Cisco Switch Name...................... *****
--More-- or (q)uit
Secondary Cisco Switch IP Address................ Not Configured
Tertiary Cisco Switch Name.......................
Tertiary Cisco Switch IP Address................. Not Configured
Administrative State ............................ ADMIN_ENABLED
Operation State ................................. REGISTERED
Mirroring Mode .................................. Disabled
AP Mode ......................................... Monitor
Public Safety ................................... Global: Disabled, Local: Disabled
Remote AP Debug ................................. Disabled
S/W Version .................................... 5.0.148.2
Boot Version ................................... 12.3.7.1
Mini IOS Version ................................ 3.0.51.0
Stats Reporting Period .......................... 180
LED State........................................ Enabled
PoE Pre-Standard Switch.......................... Enabled
PoE Power Injector MAC Addr...................... Disabled
Number Of Slots.................................. 2
AP Model......................................... AIR-AP1242AG-E-K9
IOS Version...................................... 12.4(13d)JA
Reset Button..................................... Enabled
AP Serial Number................................. FCZ114180JC
AP Certificate Type.............................. Manufacture Installed
Management Frame Protection Validation........... Enabled (Global MFP Disabled)
AP User Mode..................................... AUTOMATIC
I've done reboot of AP and controller, but situation is the same.
Scott Fella Tue, 09/09/2008 - 06:24
  • Hall of Fame,
    2017 Wireless
I saw that and tried it on one of our 2006WLC and I did get the smae results.... what model WLC are you using and code version.
vladskuba Tue, 09/09/2008 - 06:45
I'm running 4404-100. Software version 5.0.148.2.
770801tvdhaar Thu, 10/09/2008 - 23:03
Have you resolved this problem? I'm experiencing the same problem even though I'm doing DHCP with reservations and domain names.
vladskuba Thu, 10/09/2008 - 23:43
No, I haven't. I'm going to open TAC case on Cisco.
I'll inform you as soon as I'll know something new.
vlad.kabatov Mon, 10/13/2008 - 07:03
not sure why it didn't post my previous reply, but it appears that your access points are running in autonomous mode. That's from the output of show CDP neighbors. A lightweight AP will have "LAP" in it's name, an autonomous AP will have "AP" (AIR-LAP1242G-A-K9 VS. AIR-AP1242G-E-K9). Also, output of a lightweight AP when you SSH to it is very limited. I am not sure if you can SSH/Telnet to them. You probably need to migrate your APs to LAP mode.
To change domain in autonomous AP, do "ip domain name yourdomain" in global config.
vladskuba Mon, 10/13/2008 - 10:01
Hello, Vlad.
No, this AP's are autonomous from the box, but all are already "upgraded" to lightweight mode.
CDP shows model name aside from the image they are running. And their model is AIR-AP1242.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
