2 IPSEC sessions for 1 Tunnel
Sep 8th, 2008
3002-->5520.
Under system status of the 3002. I have:
IKE | public ip of 5520 | etc....
IPSEC | public ip of 5520 | 3DES | HMAC/SHA-1| 0 | 0 | 0 | 0
IPSEC | 0.0.0.0/0.0.0.0 | etc....
Why do i have an ipsec tunnel with a remote address for the public interface of my ASA? I don't have any split tunneling configured either?
Richard Burts Mon, 09/08/2008 - 11:31
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Marshall
Perhaps there is something that I am not understanding correctly. I thought that you were indicating that the 3002 has a VPN connection to the ASA (when you say 3002-->5520)
So why are you surprised that the 3002 has an IKE (ISAKMP) and an IPSec SA to the ASA?
If I have failed to understand some aspect of the question then please clarify.
Rick
marshall.blanco... Mon, 09/08/2008 - 11:36
Correct. The 3002 hardware client connects to an ASA 5520. Once the tunnel is established, i see 1 IKE session and 2 IPSEC sessions.
For a regular VPN user, i have 1 IKE and 1 IPSEC session...
acomiskey Mon, 09/08/2008 - 11:39
  • Green, 3000 points or more
Looks like you have multiple security assocations defined for the tunnel.
marshall.blanco... Mon, 09/08/2008 - 11:44
How do i define what SA's go with each tunnel? Is this done through the ASA or the hardware client?
acomiskey Mon, 09/08/2008 - 11:52
In the ASA, each sa would be a separate entry in the crytpo match access list. The example below would be 2 sa's.
access-list outside_cryptomap_1 extended permit ....
crypto map outside_map 1 match address outside_cryptomap_1
marshall.blanco... Mon, 09/08/2008 - 12:48
Attached is what is currently configured as far as access-list outside_cryptomaps and crypto maps.
the subnet in question would be the 10.0.29.0 subnet? I just noticed there was 2 entries for that subnet as well?
Would that be the reason why?
acomiskey Mon, 09/08/2008 - 13:43
If there are no corresponding lines like these...
crypto map outside_map x match address Outside_cryptomap_2
or
crypto map outside_map x match address Outside_cryptomap_3
...then these lines are doing nothing at all.
