Change unity setup
Sep 8th, 2008
I have a customer using CUM version 4.05. Integrated with lotus notes. Is it possible to covert the unity system to a VM only setup. or can I take a DIRT backup of the current system, build a new VM box then restore the config from the CUM build?
Overall Rating: 5 (1 ratings)
Jaime Valencia Mon, 09/08/2008 - 09:27
  • Cisco Employee,
  • Hall of Fame,
    2011
the change from UM to VMO and viceversa requires you to rebuild the server using the DIRT backup
java
if this helps, please rate
mymite060708 Tue, 09/09/2008 - 00:48
thanks, so I can take the dirt backup from UM and rebuild a new VM only server and recover it with the backup
Jaime Valencia Tue, 09/09/2008 - 06:05
  • Cisco Employee,
  • Hall of Fame,
    2011
yes, that's right
unfortunately the procedure does require the server rebuild like the one of changing the domain to which unity belongs =(
java
