Network Connectivity Help
Sep 8th, 2008
We have issues with my Cluster server not being able to ping server on the same subnet
Cluster server is patched to core switches and this is a physical HP blade server
I was able to ping the gateway address: but was unable to ping:
or any other server on the same server, which is as you see on the same subnet and VLAN
I have attached ping and tracert results as you can see what is happening.
Giuseppe Larosa Mon, 09/08/2008 - 08:05
Hello Patel,
in order to be able to help, you should provide some more info:
a)how is this server connected to the core switches: is any form of NIC teaming in use ?
b) how is the cluster managed, have you got CSM or ACE load balancers blades on the core switches ?
in this case the IP subnet could be logically divided in two parts with the CSM in the middle (CSM in bridged mode) for example.
Hope to help
