09-08-2008 08:26 AM - edited 03-15-2019 01:06 PM
Guys just a quick question. will this be able to run or rather be supported for virtualized environments? im hearing a few things and just wanted to be clear. any documenation on this fact will be greatly apperciated.
thanks
09-08-2008 08:47 AM
No. Sorry.
HTH,
Chris
09-08-2008 08:48 AM
Arvind,
If you're referring to virtualization that implies a deployment that looks and operates like multiple networks, but is actually using the same hardware and physical connectivity, then yes, CUCM 7.0 takes the first step in that direction through the support of insertion of Trusted Relay Points (TRP).
Search for "Trusted Relay Points" in the Release Notes linked here for more information:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/7_0_1/cucm-rel_notes-701.html
Hope this helps.
Michael.
09-08-2008 10:20 AM
guys thanks. im not sure i quite understand TRP though as im not too familiar with virtualization other than running vmware :). i think the customer asked if we can have his potential call manager 7.0 run on his existing VMWARE that runs all his apps.
Instead of running it on his MCS hardware.
09-08-2008 10:26 AM
TRP is essentailly an MTP that allows for QoS re-marking.
CM 7 is not supported to be run in VMWare or any other virtualization product.
Chris
09-08-2008 10:30 AM
Hi Arvind,
For running CCM on VMWare, the answer there is, as Chris stated (+5 point for you Sir), no.
If this will be a production system, then they definitely want to make sure it is running only on one of the supported platforms.
Michael.
09-08-2008 02:04 PM
thanks guys
will advise customer
