BLF Information
Answered Question
Sep 8th, 2008
I'm trying to figure out whether phones that are SCCP can use the BLF feature. From reading the CCM Help files it seems to say that the BLF/SD feature is SD only on SCCP phones? Is that correct? Thanks!
Correct Answer by Rob Huffman about 8 years 8 months ago
Hi John,
You should be "good to go" with SCCP Phones as well. Here is a good clip :)
The following Cisco Unified IP Phones support BLF speed dial for SCCP:
•Cisco Unified IP Phone 7914G
•Cisco Unified IP Phone 7940G
•Cisco Unified IP Phone 7960G
•Cisco Unified IP Phones 7941G and 7941G-GE
•Cisco Unified IP Phones 7961G and 7961G-GE
•Cisco Unified IP Phones 7970G and 7971G-GE
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/5x/50cups.html#wp1070502
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Chris Deren Mon, 09/08/2008 - 08:48
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Absolutely they can.
HTH,
Chris
johnbonog Mon, 09/08/2008 - 08:52
Thanks Chris. Does this mean I have to setup PRESENCE?
Chris Deren Mon, 09/08/2008 - 08:55
  • Hall of Fame,
No, all you need to ensure is that you have Subscribe CSS selected on the phones that will use BLF witch access to the parition of the phone you need to get presencse from.
Chris
Correct Answer
Rob Huffman Mon, 09/08/2008 - 08:52
  • Hall of Fame,
    Founding Member
    2017 IP Telephony, Unified Communications
Hi John,
Hope this helps!
Rob
