1841 router with VLAN's
Sep 8th, 2008
Hello:
I have a 1841 router. I need to support 6 VLAN's. My plan is to use 2960 switches connected to the 1841 and configure the Ethernet port as a trunk port. I have searched but have not found anything on this type of config. Does anyone have any pointers or advice on the config?
Jon Marshall Mon, 09/08/2008 - 08:47
1) Create your 6 vlans on 2960 switch eg
2960(config)# vlan 10
2960(config-vlan)# name v10
2960(config)# vlan 11
2960(config-vlan)# name v11
etc. for each vlan
2) On the port that connects the 2960 to your 1841 router
int fa0/1
switchport mode trunk
(no need to specify encapsulation as 2960 only supports 802.1q
3) On 1841
int fa0/0.10
encapsulation dot1q 10
ip address 192.168.5.1 255.255.255.0
int fa0/0.11
encapsulation dot1q 11
ip address 192.168.6.1 255.255.255.0
etc.. for each vlan.
Note that the interface number does not have to match the vlan number but the encapsulation dot1q must match the vlan number.
Jon
Giuseppe Larosa Mon, 09/08/2008 - 08:49
Hello Harrison,
if your 1841 hasn't an etherswitch module, you can use the old approach:
switch side: layer 2 trunk port with 6 vlans permitted using 802.1Q
router side: a FE/Ge port with:
no ip address on main interface
int fa0/0.30
encapsulation dot1q 30
ip address x.x.x.x 255.255.255.0
define 6 subinterfaces, the parameter in the enc dot1q command must match the desired vlan-id.
if you have an etherswitch module on the 1841 you can :
define the 6 vlans on the etherswitch
define 6 SVI interfaces associated to the 6 vlans (remenber the no shut)
define a l2 trunk for each 2960 carrying the 6 vlans
use this config guide as a reference
http://www.cisco.com/en/US/docs/ios/lanswitch/configuration/guide/12_4/lsw_12_4_bk.html
Hope to help
Giuseppe
