T38 Fax Server to H323 Gateway (PSTN)
Sep 8th, 2008
Right here goes, inbound faxing is working great, I have a fax server GFI Faxmaker running a Brooktrout SR140 FOIP boardless driver. Outbound faxing fails every time. Here is the config of the 2651XM router: -
FAXGateway#sh run
Building configuration...
Current configuration : 1994 bytes
version 12.3
hostname FAXGateway
boot-start-marker
boot-end-marker
enable secret
no network-clock-participate slot 1
no network-clock-participate wic 0
network-clock-select 1 E1 1/0
no aaa new-model
ip subnet-zero
ip cef
no ftp-server write-enable
isdn switch-type primary-net5
voice-card 1
voice call send-alert
voice call convert-discpi-to-prog tunnel-IEs
voice service pots
voice service voip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none
h323
no call service stop
controller E1 1/0
pri-group timeslots 1-31
controller E1 1/1
interface FastEthernet0/0
ip address 10.0.1.154 255.0.0.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip h323-id 690470
h323-gateway voip bind srcaddr 10.0.1.154
interface Serial0/0
no ip address
shutdown
no fair-queue
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial1/0:15
no ip address
isdn incoming-voice voice
no cdp enable
ip classless
ip http serve
control-plane
voice-port 1/0:15
bearer-cap Speech
dial-peer voice 781453 pots
description Use this to dial any number out
destination-pattern .
progress_ind alert enable 8
clid network-number 690471
no digit-strip
direct-inward-dial
port 1/0:15
dial-peer voice 690471 voip
description To FAX
destination-pattern 690471
session target ipv4:10.0.1.152
session transport udp
codec g711alaw
no vad
dial-peer voice 1 voip
description incoming from FAX
numbering-type unknown
incoming called-number .
codec g711alaw
no vad
gateway
timer receive-rtp 1200
Attached are 2 files with ISDN q931 debug and DialPeer debugs
file 1 is a CSIM start that works, file 2 is a call originating from the FAX server that fails. I think it is a signalling issue but don't know where the responsibility lies to fix it, is it GFI/Cantata or Cisco or PSTN service provider?
Any help would be great, do I need to use a h323 gatekeeper? I really do not know what is causing the problem.
Cheers
Stuart
Overall Rating: 5 (1 ratings)
stuart.pannell Fri, 09/26/2008 - 03:24
I have resolved this issue, the fax server was forcing all calls out to the PSTN as ISDN National, so the PSTN was not understanding the numbers dialed. I added ISDN maps to map the dialed numbers to National or international and changed my dial-peers to only send national and international numbers without prefix codes i.e drop the prefix '0' for national and prefix '00' for international and prefix local numbers with '1624' for local isle of man dialing.
