PVLANs...again
bjw
Level 4
Level 4
I am having issues configuring PVLAN using just trunks.
Here's the secenario... two VLANs are being trunked from a 3560 to a 4503 (VLAN0030 and VLAN230). From the 4503 I have a port trunked on to an upstream 2811.
I created a primary Vlan (VLAN0003) and a secondary isolated Vlan (VLAN0030), did the associatied and mappings per the Cisco docs. I cannot get to/from the secondary or primary VLANs from the router gateway.
Here's some output.
WRF4503-249#show vlan
VLAN Name Status Ports
1 default active Gi1/1, Gi1/2, Gi1/3, Gi1/4
Gi1/5, Gi1/6, Gi1/7, Gi1/8
Gi1/9, Gi1/10, Gi1/11, Gi1/14
Gi1/15, Gi1/16, Gi1/17, Gi1/18
Gi1/19, Gi1/20
3 PRIMARY
30 SECONDARY active
230 CLIENTS active
1002 fddi-default act/unsup
1003 trcrf-default act/unsup
1004 fddinet-default act/unsup
1005 trbrf-default act/unsup
WRF4503-249#show vlan priv
Primary Secondary Type Ports
3 30 isolated Gi1/12, Gi1/13
WRF4503-249#
WRF4503-249#show int trunk
Port Mode Encapsulation Status Native vlan
Gi1/12 trunk-pvlan-pro n-802.1q trunking 3
Gi1/13 trunk-pvlan 802.1q trunking 30
Port Vlans allowed on trunk
Gi1/12 3,30,230
Gi1/13 3,30,230
Port Vlans allowed and active in management domain
Gi1/12 230
Gi1/13 3,30,230
Port Vlans in spanning tree forwarding state and not pruned
Gi1/12 230
Gi1/13 3,230
WRF4503-249#
interface GigabitEthernet1/12
description Trunk to ROUTER
switchport private-vlan trunk native vlan 3
switchport private-vlan trunk allowed vlan 3,30,230
switchport private-vlan association trunk 3 30
switchport mode private-vlan trunk promiscuous
switchport nonegotiate
no logging event link-status
no logging event trunk-status
no snmp ifindex persist
end
WRF4503-249#
WRF4503-249#show run int g1/13
Building configuration...
Current configuration : 476 bytes
interface GigabitEthernet1/13
description Trunk to 3560
switchport trunk native vlan 30
switchport trunk allowed vlan 3,30,230
switchport private-vlan trunk native vlan 30
switchport private-vlan trunk allowed vlan 230
end
WRF4503-249#
interface Vlan1
no ip address
interface Vlan3
ip address 172.12.3.249 255.255.255.0
private-vlan mapping 30
interface Vlan30
ip address 172.12.230.249 255.255.255.0
shutdown
interface Vlan230
description Clients
vlan 3
name PRIMARY
private-vlan primary
private-vlan association 30
vlan 30
name SECONDARY
private-vlan isolated
vlan 230
name CLIENTS
ROUTER INTERFACE
interface FastEthernet0/0
description Trunk CORE
no ip address
no ip route-cache cef
no ip route-cache
no ip mroute-cache
duplex auto
speed auto
no mop enabled
interface FastEthernet0/0.3
encapsulation dot1Q 3 native
ip address 172.12.3.254 255.255.255.0
no ip route-cache
no ip mroute-cache
interface FastEthernet0/0.230
encapsulation dot1Q 230
ip address 172.12.230.254 255.255.255.0
t814687
Hello Bill,
Just some general notes on your config..
1) When you use PVLAN trunk the device on the other end must support PVLAN tagging. Your 2811 is a regular IOS router and is not aware of PVLANs so I would not configure PVLAN trunking to that device.
2)Not exactly sure what you trying to acheive with the config as I see that your router and 4500 are configured to route traffic between vlan 3 and 230
serg
