Upgrading a 1841 to AdvSecurity IOS
Answered Question
Sep 8th, 2008
Hi.
I wish to deploy on a 1841 router (32 MB Flash/128 MB DRAM) the ADVSECURITY IOS.
For what i've seen, it needs a memory upgrade: i have decided to extend it to 128 MB flash and 384 MB DRAM (the max available).
I have noticed however there are 2 possible modules to upgrade the RAM: MEM180X-128U384D and MEM180X-256D=. What's is the right module i have to purchase for the the router? What is the difference between them?
And for the flash?
Thank you anticipately
C
Correct Answer by cleidh_mor about 8 years 10 months ago
MEM180X-128U384D is what you're looking for. The part number indicates that this is an upgrade from 128Mb to 384Mb. The other part no would seem to be a 256Mb module. It's possible that there's no actual difference between them, but it's always best to order the upgrade kit.
In terms of flash, it's just a 128Mb compact flash card you need. I'm not sure what the Cisco part number will be.
Overall Rating: 3 (1 ratings)
Correct Answer
cleidh_mor Tue, 09/09/2008 - 00:47
