Question regarding the 1242AG with Antenna
Sep 8th, 2008
I am trying to connect 1242AG with the Cisco Multiband Diversity Omnidirectional
Ceiling-Mount Antenna (AIR-ANTM4050V-R)which got two connection. Should I connect two primary (2.4Ghz and 5ghz) or should I connect both on 2.4ghz) we use 2.4ghz mainly
Scott Fella Mon, 09/08/2008 - 16:45
If you require the need for the 2.4GHz vs the 5GHz, then use the antenna for the 2.4GHz and not the 5GHz. This way you can still use diversity. If you require the use of the 5GHz, then I would suggest you purchase another antenna.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
