Encapsulation dot1Q
Answered Question
Sep 8th, 2008
any one know why my 2900xl wont take the encapsulation dot1Q command it is using version 12.3
Correct Answer by Giuseppe Larosa about 8 years 7 months ago
Hello Shane,
some low end switches support only ISL and others support only 802.1Q. Try to use ISL on both ends of the links.
For this reason some switches don't even accept the command switchport trunk encapsulation with any parameter because there is no choice
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Correct Answer
Giuseppe Larosa Mon, 09/08/2008 - 11:23
  • Hall of Fame,
    Founding Member
Hello Shane,
Hope to help
Giuseppe
matej.polak Mon, 09/08/2008 - 12:13
are you using these commands?
switchport mode trunk
2900xl does not have 12.3 version.
naitsirhc81 Mon, 09/08/2008 - 17:24
It will only support dot1q. Therefore there is no need to specify your encapsulation.
