iBGP Multi-Link Question
Answered Question
I'm in a scenario where I have two routers, configured with two loopbacks, connected together via two links. I'm in the process of transitioning from one loopback to the other and I was wondering if there are any caveats to having two sessions up...one BGP session to the first lookback (existing), then another BGP session up to the second loopback (new).
I don't believe their should be any issues with this...and I don't see any documentation suggesting otherwise...just thought I'd ask to be certain :-)
ROUTER1============ROUTER2
Lo1:10.1.1.1/32 Lo1:10.1.2.1/32
Lo2:10.1.1.2/32 Lo2:10.1.2.2/32
Correct Answer by Giuseppe Larosa about 8 years 5 months ago
Hello Jeff,
I think you shouldn't have any problem in this migration to loop2 iBGP endpoints.
It should be better if iBGP next-hop = OSPF router-id it is more safe it will pass the sync test (if sync is not disabled).
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Giuseppe Larosa Mon, 09/08/2008 - 12:51
Hello Jeff,
your understanding is correct: you can setup the second iBGP session that uses the loop2 on both routers.
Some issues can arise if redistributing ospf into/from BGP: it has been noticed that is necessary to have OSPF router-id = BGP router-id
If there isn't any redistribution of BGP or into BGP it should be a smooth transition.
Hope to help
Giuseppe
Correct Answer
Giuseppe Larosa Mon, 09/08/2008 - 22:18
Hello Jeff,
Hope to help
Giuseppe
