VPN Problems using Verizon air card
I am having a problem with a vpn tunnel using a verizon air card.
Problem - When i connect to my Pix 501 with Cisco VPN client 5.0.03.0530 i am unable to ping any known good address on the remote network.
I have check the statistics and it shows that it is encrypting and decrypting packets, (According to Tac engineer the tunnel is working) but if i try to ping an address or browse by address i get an error.
I have tested this with my computer plugged into my local lan and i can pass traffic all day long.
Has anyone seen this problem before and if so what is the fix?
Shane
