Control path on mobility member is down
Sep 8th, 2008
  • Silver, 250 points or more
Greetings,
I have a tac case open on this issue but wanted to see if any of you may have encountered this problem.
Our guest controller loses is connection path every 5 days for 10 or fifteen minutes and then works fine for another five days until it does it again.
Any insight would be greatly appreciated
Thanks much-
Scott Fella Mon, 09/08/2008 - 17:30
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Did you happen to of changed the ip address of the management, ap-manager or VIP?
Darren Ramsey Mon, 09/08/2008 - 18:46
Same here...
Upgraded from 4.0.217 to 4.2.130 for 11N support. Thought a MD release would be safe, nothing but problems for the last week. We are experiencing CSCsr40109 and CSCsr89694. 217 ran solid for around a year, now our guest anchors are broken, data and control paths flapping continuously, and issues with the mobility group causing roaming problems with Vocera. We are also seeing a third issue with DHCP not passing through the guest anchor and only a reboot will correct.
Ask your TAC engineer to execute the appropriate hidden "devshell" command from the console, which will show the Runtime Mobility Member List. If you have a version other than 0 or 2, then you are hitting the mobility bug. As for the anchor issue, the DE is looking over some debugs and captures, but no workarounds yet. This seems to be a random issue that only effects some controllers. Only 1 controller out of 10 are having this issue at our site.
patoberli Mon, 09/08/2008 - 23:32
  • Bronze, 100 points or more
I also had this issue. After a few days of debugging I found the cause, it was a configuration failure on my site.
I need to mention that I have two WiSM blades.
The issue was that the wism service-vlan was the same vlan as the native-vlan. Because of that I received the errors. After I created a new vlan just for the service-port and put them into that vlan and assigned new ip addresses, everything was fine.
john.preves Fri, 09/12/2008 - 12:38
Thanks folks I'm looking into this now...
Darren Ramsey Fri, 09/12/2008 - 12:43
John,
I have narrowed down the issue to having more than 5 entries in the guest anchor peer list. When I add a 6th entry, the lowest IP in the peer list starts flapping. Does it sound like you are seeing the same issue?
john.preves Fri, 09/12/2008 - 13:03
I currently only have one entry but thanks, I know what to be looking for when we add the others!
Trending Topics - Security & Network
