CCM 4.2.3 Phones wont fail over to subscriber
Sep 8th, 2008
Hi All
For some reason the phones will go off line rather than fail over to the subscriber, all the phone configurations show the second call manager, all the services match, DHCP and TFTP are duplicated on the subscriber but fail over does not happen. Any ideas?
Jaime Valencia Mon, 09/08/2008 - 14:47
go to the TFTP service parameters, change build cnf files to build all, restart TFTP
reset phones and try again
make sure that if using DNS you have the proper entries, otherwise use IPs
check connectivity and the status of ccm service in SUB
if this helps, please rate
david-lima Mon, 09/08/2008 - 19:25
Hi friend, also check if in the System->CCM Group configuration are both servers (Publisher and Subscriber) and it is assigned to the IP Phones or ckeck if you have a broken SQL replication subscription using DBLHelper (C:/Program Files/cisco/bin - Publisher only) or through Microsoft SQL Servers > SQL Server Group > 'Server Name' > Replication Monitor.
I hope ths help
Michael Owuor Tue, 09/09/2008 - 02:46
Another possible cause worth checking into might be that the CallManager service on the subscriber is not running.
