Sascha Monteiro Mon, 09/08/2008 - 17:18
  • Silver, 250 points or more
Please specify the version you are running!
in cucm6 you can run a sql query through AXL or commandline;
select dnorpattern,ismessagewaitingon from numplan
hth
jose.padilla Tue, 09/09/2008 - 09:35
I tried the AXL SQLQuery. I always receive this:
9042f
No matter the light is on or off.
Do you know why is this happening?
Thanks in Advance.
tim.giles Tue, 09/16/2008 - 04:04
alternatively, I think you can check the MWI state on individual lines by searching for the device (device > phone) and clicking on its IP. It should tell you whether the message waiting status is "off (no)" or "on (yes)".
Please rate useful posts....
