Joe Clarke Mon, 09/08/2008 - 22:02
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
SSH client in what sense? What are you trying to do in LMS using SSH?
Joe Clarke Tue, 09/09/2008 - 18:59
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Which device console? Please post a screenshot illustrating what application in LMS you are using.
Joe Clarke Sat, 10/11/2008 - 12:36
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You must be using Campus Manager 5.0.3 or later. Create a file in your home directory on your client called campusmgr.properties. Within that file add one line:
CMSSH=PATH
Where PATH is the path to PuTTY.exe. For example:
CMSSH=C:\\PROGRA~1\\PuTTY\\PuTTY.exe
(Note: The double '\' characters are necessary.)
Then restart your browser.
Joe Clarke Tue, 10/14/2008 - 08:44
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
When you login on Windows, and launch a DOS prompt, what path are you in? For example, C:\Documents and Settings\marcus. That is your home directory.
