Content Security Module for ASA - SSM-CSC
Answered Question
Sep 8th, 2008
Is it possible with that module to filter some of the users filtered (like restricting facebook.com) and others unfiltered? I mean if user based filtering is possible?
thx
Correct Answer by suschoud about 8 years 5 months ago
In asa,you define what traffic should be sent to csc for scanning purpose.
In the acl where you define the traffic,add an entry denying the source ip addresses for which you do not want filtering to be done.
class-map CSC-C
match access-list CSC-TRAFFIC
policy-map global_policy
class CSC-C
csc fail-open
access-list CSC-TRAFFIC line 1 extended deny tcp host x.x.x.x any eq 80
access-list CSC-TRAFFIC line 2 extended permit tcp any any eq 80
access-list CSC-TRAFFIC line 3 extended permit tcp any any eq smtp
In the above example,web traffic from x.x.x.x will not be sent to csc...
Sushil
Overall Rating: 4 (1 ratings)
edunn@mtm.com Tue, 09/09/2008 - 05:55
You will need some type of URL filtering software like WebSense to filter based on user.....
Correct Answer
suschoud Tue, 09/09/2008 - 09:47
class-map CSC-C
class CSC-C
csc fail-open
Sushil
