Light weight Access Point problem
Sep 8th, 2008
Hi all,
I have wireless network with Wireless Lan Controller 2100 and Light Weight Access Point 1300.All thing run well.
But when we need some change on network, i changed IP of LAP 1300 to incorrect IP address. So it can not communicate with Wireless Lan Controller.
I try to config it by console but cannot becaused it had registered with WLC before.
Any one can help.
Overall Rating: 4 (2 ratings)
nkariyawasam Tue, 09/09/2008 - 02:23
According to my experience you may have two ways to get out;
1. Try to log in to LAP using Cisco userid/password before it getting connected to WLC. Then clear it's private config using "clear private-config" command.
2. Irrespective of the configured IP of hte AP, if you plug the LAP to the AP-management VLAN of WLC it should get connected to WLC ( privided that Ap Management VLAN has a DHCP server) Then you can create override user ID on AP , log in to AP using the new user id instead of "Cisco", and then re-config hte AP IP.
NalakaK.
Scott Fella Tue, 09/09/2008 - 04:15
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Here are some steps you need to do:
First, check the flash:
lap_1300#dir
Directory of flash:/
2 -rwx 279 May 09 2008 11:52:20 +00:00 env_vars
4 -rwx 6168 May 09 2008 11:52:20 +00:00 private-multiple-fs
6 drwx 256 May 09 2008 11:49:05 +00:00 c1300-k9w8-mx.124-3g.JA2
5 drwx 128 Mar 01 2002 00:03:43 +00:00 c1300-rcvk9w8-mx
15998976 bytes total (10716672 bytes free)
Then delete the LWAPP image:
lap_1131#delete /r /f flash:/c1300-k9w8-mx.124-3g.JA2
Not the one the has rcv in it!!!!!!
Thirdly reload the AP:
lap_1300#reload
Then issue a clear lwapp private-config
You'll end up with a clear AP.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
