satish_zanjurne Mon, 09/08/2008 - 23:11
  • Silver, 250 points or more
1.Don't start with IPSec configuration directly.
2.First see the whether link is up between peers & peer can ping each other.
3.Use show interface to see the interface status..
HTH..rate if helpful..
arupbiet2006 Mon, 09/08/2008 - 23:14
hello...every thing is ok...could u send me a ip sec config
satish_zanjurne Mon, 09/08/2008 - 23:38
1.tell me on which devices you are trying to establish the IPsec ??
satish_zanjurne Tue, 09/09/2008 - 00:00
First Router Config
hostname R2
crypto isakmp policy 10
authentication pre-share
crypto isakmp key ciscokey address 200.1.1.1
crypto ipsec transform-set myset esp-3des esp-md5-hmac
crypto map myvpn 10 ipsec-isakmp
set peer 200.1.1.1
set transform-set myset
!--- Include the private-network-to-private-network traffic
!--- in the encryption process:
match address 101
interface Ethernet0/0
description------LAN Interface-----
ip address 172.16.1.1 255.255.255.0
ip nat inside
ip virtual-reassembly
interface Ethernet1/0
description----WAN interface where other peer is connected---
ip address 100.1.1.1 255.255.255.0
ip nat outside
crypto map myvpn
ip route 0.0.0.0 0.0.0.0 100.1.1.254
!--- Except the private network from the NAT process:
ip nat inside source list 175 interface Ethernet1/0 overload
access-list 101 permit ip 172.16.1.0 0.0.0.255 10.1.1.0 0.0.0.255
access-list 175 deny ip 172.16.1.0 0.0.0.255 10.1.1.0 0.0.0.255
access-list 175 permit ip 172.16.1.0 0.0.0.255 any
--------------------------------------------Router R3
hostname R3
crypto isakmp key ciscokey address 100.1.1.1
set peer 100.1.1.1
match address 101
descrption-----LAN Interface----
ip address 10.1.1.1 255.255.255.0
ip nat inside
description---WAN Interface
ip address 200.1.1.1 255.255.255.0
ip nat outside
crypto map myvpn
ip route 0.0.0.0 0.0.0.0 200.1.1.254
ip nat inside source list 122 interface Ethernet1/0 overload
!--- Except the static-NAT traffic from the NAT process if destined
!--- over the encrypted tunnel:
access-list 101 permit ip 10.1.1.0 0.0.0.255 172.16.1.0 0.0.0.255
access-list 122 deny ip 10.1.1.0 0.0.0.255 172.16.1.0 0.0.0.255
access-list 122 permit ip 10.1.1.0 0.0.0.255 any
HTH...rate if helpful...
satish_zanjurne Tue, 09/09/2008 - 00:08
Make sure you are adding proper default routes..
arupbiet2006 Tue, 09/09/2008 - 00:50
when i prompt crypto ipsec transform-set command then i can't enter this myset esp-3des esp-md5-hmac
satish_zanjurne Tue, 09/09/2008 - 01:26
hi,
myset is the name of transform set, so you need to type it as it is. It is not the keyword, but esp-3des & esp-md5-hmac are keyword, you can get this by using "?" or pressing tab.
