Managemnt access to a ASA5505 via NEM connection
Answered Question
Sep 9th, 2008
I'm working with a ASA5505 NEM setup.
Everyting is working fine except accesing the device from the other side of the tunnel. From the ASA LAN i can access the device via HTTPS, Telnet and SSH, but this doesn't work comming via the tunnel. I'm running version 7.2(4).
Any idea what I'm doing wrong?
Correct Answer by JORGE RODRIGUEZ about 8 years 7 months ago
There is no attachement in your post..
can you verify asa have management access :
show run | inc management
if no output from above configure asa with bellow statement, then try accessing asa via tunnel.
management-access inside
PLS rate any helpful post
Rgds
Jorge
Overall Rating: 5 (1 ratings)
Correct Answer
JORGE RODRIGUEZ Tue, 09/09/2008 - 16:26
  • Green, 3000 points or more
Rgds
Jorge
