How configure Unity Connection 2.1 for hearing anouncement only
Answered Question
Sep 9th, 2008
hi,
we have a unity connection 2.1. There is a voice mail box for a directory number. A call incoming to this number is redirected to the voice mail. The caller will be get an announcement, but will not be able to leave a message. After getting the announcement, unity will end the call.
How configure this?
Correct Answer by Jaime Valencia about 8 years 9 months ago
there are several options under the subscriber, one of them is After message:
and you have a drop down menu, default is take a message but there is another one called hang up. just change that one
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
thfergus Tue, 09/09/2008 - 06:26
  • Cisco Employee,
Please check the "after greeting" call action for this subscriber. Ensure the after greeting call action is set to "take message"
Correct Answer
Jaime Valencia Tue, 09/09/2008 - 06:26
  • Cisco Employee,
  • Hall of Fame,
    2011
java
mschuermans Fri, 12/19/2008 - 14:51
I want to configure the same on a Unity connection 1.2. Is it possible ??
lindborg Fri, 12/19/2008 - 15:58
  • Cisco Employee,
sure - you can do this with any version of Unit yor connection back many versions - there's been an "after greeting" action there that includes multiple options (including take message or "hangup") for some years now.
