Cfwd TO TDM connected Voicemail
Sep 9th, 2008
anyone got any ideas on the following, apart from the obvious use a unity!
cluster2 - ictrunk - cluster1 - qsig - pbx - voicemail
Thats the setup, if you divert phone from cluster1 to voicemail works fine.
If you divert a phone in cluster2 to voicemail, it gets to the platform but the original called party string is missing?
As this works okay from cluster1, i'm thinking that it has to be either something in the cluster2 config, or the ICTrunk?
thanks
Aaron Harrison Wed, 09/10/2008 - 03:48
  • Community Spotlight Award,
    Member's Choice, May 2015
No need to use Unity, your setup should work fine.
On your ICT, verify that you have these properties checked:
Redirecting Number IE Delivery - Outbound (on the no-VM cluster)
Redirecting Number IE Delivery - Inbound (on the cluster with the VM/qsig setup)
Or check both on both ends (not necessary, but should someone on the VM cluster forward to someone on cluster2 then it should show proper forward info).
If these are checked already, check for any translations etc that may be causing the number to not match what's configured on your Voicemail boxes...
Aaron
Please rate helpful posts.!
