monitoring network traffic
Sep 9th, 2008
Hi all. I would like to know if there is any tool from cisco that you can download with cco id that you use for monitoring network traffic for bottlenecks, bandwidth hogging by PCs etc. Thks in advance.
Jose Moreno Tue, 09/09/2008 - 01:13
Hello!
I think the closest to your description is Health & Utilization Monitor, a plugin for CiscoWorks LMS with which you can monitor SNMP OIDs (bandwidth, memory utilization, etc) on Cisco devices.
You can find more info about it in http://www.cisco.com/go/hum
Hope this helps!
Jose
ropethic Wed, 09/10/2008 - 02:02
  • Silver, 250 points or more
also you can enable netflow on your routers
