WLC audit reports on Lobby ambessador activities
Answered Question
Sep 9th, 2008
Is there any way that we can get an audit trail report on the activities of user "Lobby ambesador" from wither WLC or WCS ?
Correct Answer by Rob Huffman about 8 years 6 months ago
Hi Nalaka,
Hope all is well :)
Maybe this is what you are looking for;
Logging the Lobby Ambassador Activities
The following activities are logged for each lobby ambassador account:
•Lobby ambassador login: WCS logs the authentication operation results for all users.
•Guest user creation: When a lobby ambassador creates a guest user account, WCS logs the guest user name.
•Guest user deletion: When a lobby ambassador deletes the guest user account, WCS logs the deleted guest user name.
•Account updates: WCS logs the details of any updates made to the guest user account. For example, increasing the life time.
Follow these steps to view the lobby ambassador activities.
Note You must have superuser status to open this window.
Step 1 Log into the Navigator or WCS user interface as an administrator.
Step 2 Click Administration > AAA, then click Groups in the left sidebar menu to display the All Groups window.
Step 3 On the All Groups windows, click the Audit Trail icon for the lobby ambassador account you want to view. The Audit Trail window for the lobby ambassador displays.
This window enables you to view a list of lobby ambassador activities over time.
•User: User login name
•Operation: Type of operation audited
•Time: Time operation was audited
•Status: Success or failure
Step 4 To clear the audit trail, choose Clear Audit Trail from the Select a command drop-down menu and click GO.
http://www.cisco.com/en/US/docs/wireless/wcs/4.2/configuration/guide/wcsmanag.html#wp1076868
http://www.cisco.com/en/US/docs/wireless/technology/guest_access/technical/reference/4.1/GAccess_41.html#wp1001609
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Tue, 09/09/2008 - 05:35
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Nalaka,
Hope all is well :)
Hope this helps!
Rob
