PIX no route to....
Sep 9th, 2008
PIX-501, Version 6.3(5)
My Interfaces are:
ip address outside
ip address inside
My routing table:
outside 1 OTHER static
inside 1 OTHER static
inside 1 CONNECT static
outside 1 CONNECT static
The inside interface is default-gateway for all traffic from the inside. The default route points to the outside. Some people want to communicate to a network via a gateway which is on the inside.
Whenever a connection attempt is made I see a log entry
%PIX-6-110001: No route to from
Currently I've no idea why this occors and would be grateful for any suggestions.
Overall Rating: 5 (1 ratings)
matej.polak Tue, 09/09/2008 - 02:56
Traffic that wants to leave the same interface (inside) where it has arrived will be dropped.
Source IP ( in on inside.
Destination according to the log is
According to the routing table the is on inside.
Packet arrived at inside and should be routed to inside = dropped.
