09-09-2008 02:08 AM - edited 03-13-2019 05:38 PM
I'm troubleshooting an issue with monodirectional audio.
Looking at the rtp trace I noted that the very first rtp packets have sequence number 80 81 82 and the following have seq. number 0 1 2 3 ....
Is this the cause of my problem?
Is this admitted by the rfc or not?
Thanks.
09-15-2008 10:51 AM
During compression of an RTP stream, a session context is defined. For each context, the session state is established and shared between the compressor and the decompressor. The context state consists of the full IP/UDP/RTP headers, a few first-order differential values, a link sequence number, a generation number, and a delta encoding table. Once the context state is established, compressed packets may be sent. It is admitted by RFC 2507
09-24-2008 06:47 AM
Sorry, but I cannot understand your answer.
I'm asking about rtp sequence number, not TCP.
Could you explain what you meant?
Thanks.
09-24-2008 10:17 AM
In which direction do you see this jump? Do the users report that they have two-way audio at the beginning of a call, but lose either the send or receive stream at some point?
What you describe could conceivably cause an RTP stream to fail, although I've never seen that happen. One-way audio is much more likely an ACL issue or routing problem with binding the wrong source interface address.
