3550-12g will not boot ios
Sep 9th, 2008
trying to load the c-3550-ipservicesk9-mz.122-25.sed.bin. It will not load but gives a the 'switch' prompt. What are my options at this point?
rmcarthur Tue, 09/09/2008 - 03:15
I guess you're at the switch: prompt?
If so, try "dir flash:", you may need to run "flash_init" first.
You should then see the available images (if any).
Has the switch recently been upgraded? If so there may be a boot statement pointing to the previous image.
Use "set" and check that the BOOT= either matches the image you are trying load or is blank.
