Juniper Network Connect SSL
Sep 9th, 2008
I have a user that needs to use the Juniper Network Connect client to access a remote application through my fwsm. The initial connection works but once the uid and pswd are entered you get a message from the remote server saying "The secure gateway denied the connection request from this client" If I try from a subnet outside of our firewall, it works. Has anyone had any experience with this type of connection? FWSM is running 4.0(2) Thanks.
