09-09-2008 06:49 AM - edited 03-06-2019 01:16 AM
I have to configure QoS on 3550 to identify and tag voice traffic with real-time priority (dscp 46) and rest of the traffic with default priority (dscp 0), so just need two queues, one with 90% bandwidth for non-voice traffic and 10% for voice traffic. This is what I have so far...
mls qos
class-map match-any voipclass
match access-group 190
class-map match-any dataclass
match access-group 193
policy-map voipolicy
class voipclass
set ip dscp 46
class dataclass
set ip dscp 0
interface FastEthernet0/1
switchport mode dynamic desirable
wrr-queue bandwidth 90 10 1 1
wrr-queue cos-map 1 0 1 2 3
wrr-queue cos-map 2 4 5 6 7
spanning-tree portfast
service-policy input voipolicy
interface FastEthernet0/2
access-list 190 permit udp any range 16384 32768 any range 16384 32768
access-list 190 permit udp any range 10000 11281 any range 10000 11281
access-list 190 permit udp any range 49300 49309 any eq 1719
access-list 190 permit udp any eq 1719 any range 49300 49309
access-list 190 permit tcp any range 61440 61444 any eq 1720
access-list 190 permit tcp any eq 1720 any range 61440 61444
access-list 193 deny udp any range 16384 32768 any range 16384 32768
access-list 193 deny udp any range 10000 11281 any range 10000 11281
access-list 193 deny udp any range 49300 49309 any eq 1719
access-list 193 deny udp any eq 1719 any range 49300 49309
access-list 193 deny tcp any range 61440 61444 any eq 1720
access-list 193 deny tcp any eq 1720 any range 61440 61444
access-list 193 permit ip any any
Unfortunately this config is not matching and taggin any traffic. I am not an expert on QoS, just going through the documentation and trying different options. I was able to configure cisco 2651XM, 3725 and 7204-VXR successfully with the help of Cisco documentation.
09-09-2008 07:12 AM
1.As IP phone by default marks traffic with priority 5, you need map this to DSCP , so you need to define COS to DSCP map
mls qos map cos-dscp 0 8 16 26 32 46 48 56
2.Under interface where IP phone is connected
put 5/voice traffic in seprate queue, here queue 4.Also make that queue as strict priority queue.Also assign more bandwidth to this queue.
int fa0/1
switchport voice vlan xxxx
mls qos trust cos
wrr-queue cos-map 2 2 3
wrr-queue cos-map 3 4 6 7
wrr-queue cos-map 4 5
wrr-queue bandwidth 10 10 10 70
priority-queue out
HTH..rate if helpful...
09-09-2008 07:29 AM
hi Satish
u were right about priority queue but
the thing is once u enable it with command
priority-queue out u dont need to give it bandwidth just put it as 1
according to cisco press
"with the Catalyst 3550 is that queue 4's WRR weight is set to 1 (indicating that it does not participate in the WRR scheduler because it is configured as a strict-priority queue) instead of 0 (as is the case on the Catalyst 2950)"
thank you
if helpful Rate
09-09-2008 07:25 AM
first of all
if u just trust the COS on the interface connected to the cisco IP phone the voice traffic will be marked by the phone as cos 5 and call signaling as cos 3
but first u need to ajust defualt cos-to-DSCP maping on the switch as the following:
(config)#mls qos map cos-dscp 0 8 16 24 32 46 48 56
this Maps CoS 5 to EF
in cat 3550 Q4 is the riority queue serviced first
mls qos
wrr-queue cos-map 4 4 5 6 7
priority-queue out
mls qos trust device cisco-phone
or
priority-queue out
ip access-list extended voice
permit udp any any range 16384 32767
permit tcp any any range 2000 2002
match access-group voice
class voipclass
set ip dscp 46
u dont need a class for marking traffic to cos or DSCP 0 because all traffic by default will be set to 0 as it is the defualt marking unless u do the trust and the device mark its traffic like in first interface config above
good luck
if helpful Rate
09-10-2008 04:47 AM
@marwanshawi: fyi... We're testing Voice solution for three vendors - Cisco, Avaya and Nortel however we are not buying IP phones at all. We are going to utilize existing digital phone sets tied into our IP PBX and PBX will get connected to voice gateway from three vendors. Port ranges I have in ACLs are for all three vendors. Anyway that basically rules out using "trust device cisco-phone". You suggested "wrr-queue cos-map 4 4 5 6 7" instead of "wrr-queue cos-map 2 4 5 6 7" but mapping the cos 4 5 6 7 to qid 4 wouldn't require wrr-queue bandwidth be "90 1 1 10" instead of "90 10 1 1"?
09-10-2008 06:19 AM
hi Atrey
noe when u mention about those vendors it make more senes :)
ok about the queues
as i mentioned above when u enable priority queue on the interface
on the 3550 queue 4 is the PQ so it will not be part of the bandiwidth or limit assignment so it will be serviced first then other queues will start so u can for example assign 100% of the bandwidth to 3 queues and the 4th one put 1 because it will not be part of this prosses in cat2950 put 0 in cat4500 the PQ is Q 3
i think this make senes now :)
thanks for rating and good luck
09-10-2008 11:59 AM
@marwanshawi: so that means just enabling strict priority queuing would put queue 4 in higher priority? but how about any kind of bandwidth allocation? I just want to make sure that non-voice traffic does not bleed into voice queue.
strict priority queuing does make lot of sense now and would make my life easier. thanks.
