transfer not allow in CME 4.2
Answered Question
Sep 9th, 2008
I have just set conference and transcoding in CME but I can not transfer call, even internal.
sccp local GigabitEthernet0/1
sccp ccm 10.10.10.1 identifier 1 version 4.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 2 register CFB00170eaf1d20
associate profile 1 register MTP00170eaf1d20
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729r8
codec g729ar8
codec g729abr8
maximum sessions 2
associate application SCCP
no shutdown
dspfarm profile 2 conference
codec g711ulaw
codec g711alaw
codec g729r8
codec g729ar8
codec g729abr8
maximum sessions 2
no shutdown
telephony-service
sdspfarm units 5
sdspfarm transcode sessions 2
sdspfarm tag 1 MTP00170eaf1d20
sdspfarm tag 2 CFB00170eaf1d20
CME#show dspfarm all
Dspfarm Profile Configuration
Profile ID = 1, Service = TRANSCODING, Resource ID = 1
Profile Description :
Profile Service Mode : Non Secure
Profile Admin State : UP
Profile Operation State : ACTIVE
Application : SCCP Status : ASSOCIATED
Resource Provider : FLEX_DSPRM Status : UP
Number of Resource Configured : 2
Number of Resource Available : 2
Codec Configuration
Codec : g711ulaw, Maximum Packetization Period : 30
Codec : g711alaw, Maximum Packetization Period : 30
Codec : ilbc, Maximum Packetization Period : 60
Codec : g723r63, Maximum Packetization Period : 60
Codec : g723r53, Maximum Packetization Period : 60
Codec : gsmamr-nb, Maximum Packetization Period : 60
Codec : g729ar8, Maximum Packetization Period : 60
Codec : g729abr8, Maximum Packetization Period : 60
Codec : g729r8, Maximum Packetization Period : 60
Profile ID = 2, Service = CONFERENCING, Resource ID = 2
Codec Configuration
Codec : g711ulaw, Maximum Packetization Period : 30 , Transcoder: Not Required
Codec : g711alaw, Maximum Packetization Period : 30 , Transcoder: Not Required
Codec : g729ar8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729abr8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729r8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729br8, Maximum Packetization Period : 60 , Transcoder: Not Required
SLOT DSP VERSION STATUS CHNL USE TYPE RSC_ID BRIDGE_ID PKTS_TXED PKTS_RXED
0 1 21.4.0 UP N/A FREE xcode 1 - - -
0 12 1.1.137 UP N/A FREE conf 2 - - -
Total number of DSPFARM DSP channel(s) 4
Correct Answer by Chris Deren about 8 years 8 months ago
conferecning and transcoding has nothing to do with transfers (unless you need transcoded calls). Make sure you have the following command under telephony-service
transfer-pattern .T
or somthing similar.
HTH,
Chris
Overall Rating: 5 (1 ratings)
Correct Answer
Chris Deren Tue, 09/09/2008 - 08:33
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
transfer-pattern .T
HTH,
Chris
filiberto.aguirre Tue, 09/09/2008 - 08:55
Hi Chris,
Your right, I forgot that command
now it work the tranfers
thanks for your time
regards
