Jaime Valencia Tue, 09/09/2008 - 08:02
  • Cisco Employee,
  • Hall of Fame,
    2011
if what you're looking for is ccm trace from only one device you would need to configure that before gathering the trace, that's under trace config. otherwise you will pull info from all devices as there is no filtering for that when gathering the trace
java
if this helps, please rate
jamieparr Tue, 09/09/2008 - 08:07
Ok so do I go:
realt time trace > ccm > call manager > ?
Sorry I do not know how to navigate the logs
Jaime Valencia Tue, 09/09/2008 - 08:11
  • Cisco Employee,
  • Hall of Fame,
    2011
if you want to configure them it's in serviceability
if you want to gather then open RTMT
Trace -> Collect Files
java
jamieparr Tue, 09/09/2008 - 08:11
Ok so do I go:
jamieparr Tue, 09/09/2008 - 08:17
Alternatively can I view logs of calls coming in?
Jaime Valencia Tue, 09/09/2008 - 09:38
  • Cisco Employee,
  • Hall of Fame,
    2011
traces do not have that kind of filtering, you can see all the activity from a single phone but i mean ALL activity (off-hook, on-hook, user pressed a softkey, etc)
you would need to look at the trace for incoming calls manually
java
