Unity express and default voicemailbox size
Sep 9th, 2008
Hi all, i encounter the following problem on CUE (AIM-CUE, 3.1.2.0 integrated with CUCM 6.1.2):
Impossible to change the default message size to 180s (it seems to keep on old value of 60s). I use the command "voicemail default messagesize 180"
I try to reload the module but the problem is the same.
Thanks for your help.
Julien.
GAST-UNITY# sh software lice
Installed license files:
- voicemail_lic.sig : 50 MAILBOX LICENSE
Core:
- Application mode: CCM
- Total usable system ports: 6
Voicemail/Auto Attendant:
- Max system mailbox capacity time: 840
- Default # of general delivery mailboxes: 15
- Default # of personal mailboxes: 50
- Max # of configurable mailboxes: 65
Interactive Voice Response:
- Max # of IVR ports: Not Available
Languages:
- Max installed languages: 2
- Max enabled languages: 2
Overall Rating: 5 (1 ratings)
Markus Schneider Tue, 09/09/2008 - 11:56
  • Cisco Employee,
What error are you getting when you enter this command? What is your default mailbox size (the def messagesize can't be greater)? show voicemail limits may help tell what's going on.
jtoque Wed, 09/10/2008 - 00:05
Thank you, no error when typing the command. Just knowing that when leaving a message, CUE hang up the call after around 60s.
GAST-UNITY# show voicemail limits
Default Mailbox Size (seconds): 775
Default Caller Message Size (seconds): 180
Maximum Recording Size (seconds): 900
Default Message Age (days): 30
System Capacity (minutes): 840
Default Prompt Language: systemDefault
Operator Telephone:
Maximum Broadcast Size (seconds): 300
Broadcast Message Age (days): 30
Broadcast Message MWI: disabled
Play Caller Id: disabled
Mandatory Message Expiry: disabled
Mailbox Selection: last-redirect
Julien.
kadambari.beelw... Fri, 10/31/2008 - 10:49
I see that Default Caller Message Size is 60 which is very less, how do I change this value for whole CUE rather than going into every user?
UC500-CUE# show voicemail limits
Default Caller Message Size (seconds): 60
Default Prompt Language: en_US
Operator Telephone: 0
Rob Huffman Fri, 10/31/2008 - 11:07
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Kadambari,
This is set under the system defaults;
messagesize messagesize-seconds-Sets the maximum number of seconds for a caller's message stored in a mailbox.
# voicemail default messagesize 120
SUMMARY STEPS
1. config t
2. voicemail capacity time minutes
3. voicemail defaults {expiration days | language | mailboxsize mailboxsize-seconds |
messagesize messagesize-seconds}
4. voicemail operator telephone tel-number
5. voicemail recording time minutes
6. exit
7. copy running-config startup-config
From this good doc;
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel2_0/ccm_cli/ch3sys.html#wpxref56399
Hope this helps!
Rob
Rob Huffman Wed, 09/10/2008 - 04:44
  • Hall of Fame,
    Founding Member
Hi Julien,
I think that the problem here is that the "Default" setting which you changed will only be applied to "new" mailboxes. Can you please try this config for the specified user;
For a single user:
1. config t
2. voice mailbox owner name [size seconds]
3. default parameter
4. description "text"
5. enable
or
disable
6. expiration time days
7. greeting {alternate | standard}
8. mailboxsize seconds
9.**** messagesize seconds
10. (Optional) no parameter
11. tutorial
12. zerooutnumber "number"
13. end
14. exit
15. show voicemail {detail {mailbox | user} name | limits | mailboxes [idle days] | usage | users}
16. copy running-config startup-config
http://www.cisco.com/univercd/cc/td/doc/product/voice/unityexp/rel2_0/ccmcligd/ch4users.htm#wp1036448
Hope this helps!
Rob
jtoque Mon, 09/15/2008 - 23:21
Hi Rob, i'm going to try, i will rate if it helps. Thanks a lot. Julien.
Rob Huffman Tue, 09/30/2008 - 04:29
  • Hall of Fame,
    Founding Member
Hi Julien,
I see, so the problem was not related to the mailbox size at all :) +5 points for posting back with your resolution. Many thanks!
Take care,
Rob
