ASA 5510 OWA Exchange 2003
acomiskey Tue, 09/09/2008 - 10:44
  • Green, 3000 points or more
Is the exchange server on the inside or is there a dmz?
I assume you are trying to use the public ip address of the server from the inside?
suschoud Tue, 09/09/2008 - 11:39
  • Gold, 750 points or more
You would have an existing static for the exchange server
static (inside,outside)
Issue :
no static (inside,outside)
static (inside,outside) dns
By the above commands,you are essentially adding dns keyword at the end of static statement.
This should take care of the issue.
Sushil
acomiskey Tue, 09/09/2008 - 11:46
Yes...if he is using an external dns server.
