Call Trnsfer
Sep 9th, 2008
Hi all,
Hi have install on the customer unity 4.2, i want the configure the folowing scenario :
A call cames in to the call manager and is forward to the unity the unity plays a greeting message and then transfer the call to a unsubscriber for the unity.
Can any one tell me if this is possible and how its done.
Many thanks
Jaime Valencia Tue, 09/09/2008 - 10:53
  • Cisco Employee,
  • Hall of Fame,
    2011
create a CTI RP with CFA to VM, create a call routing rule to get the call, send it to a call handler and after the greeting attempt a transfer to another call handler which has set under transfer options "yes, ring subscriber at this extension"
java
if this helps, please rate
patcbr600 Tue, 09/09/2008 - 14:25
When configuring the CTI route point should i also create any user to associate the route-point. This is because i have create the cti rp but the cti rp does not register with the CM.
Jaime Valencia Tue, 09/09/2008 - 16:08
  • Cisco Employee,
  • Hall of Fame,
    2011
CUCM 101: CTI route points unless used for a JTAPI app (CUE, UCCX, UCCE, etc) never register but they can work forwarding calls. if used with a JTAPI app then you DO need to associate the JTAPI user to them, only then they will show up as registered
java
