Link in FMWeb email reports.
Sep 9th, 2008
I started using the built in reports from the FMServer/Webserver to send some automated reports out via email. But the links for images etc all are broken. Some of them just start with "/" like the report generator just assumes they are local filesystem links, and some just start with "localhost://".
Apparently by default everything assumes you will be viewing the generated reports directly from the FMServer Web site.
IS there a way to fix these links so they work correctly?
Michael Brown Thu, 09/11/2008 - 02:38
Please open a Cisco Service request for this issue. Depending on the version of FM server you are working with, TAC might be able to provide instructions to correct the image links. If the problem is still persistent in the current versions, TAC can open a defect against the product so that future versions of FM server do not have this issue. Sounds like the images could be embedded in the report file.
Trending Topics: Storage Networking
