spremkumar Tue, 09/09/2008 - 11:52
  • Red, 2250 points or more
did u check the connectivity between your switch and the pc ? are you able to ping the ip ? if possible do log on to the console port of the switch and find out the status of the switch.
regds
cadimuccio Tue, 09/09/2008 - 12:08
Yes.
I ping to the sw, the operation is OK.
I can access by CLI and network assistant. by this the methods ...no problem
The SW default IP address is 10.0.0.1
My PC is 10.0.0.2 (take by DHCP).
But is imposible config over the running express setup, and the client try more times, !!!!
spremkumar Tue, 09/09/2008 - 12:19
hi
whts the error message you are getting when you are trying to access the switch ?
are you getting any error pertaining to the application ?
regds
cadimuccio Tue, 09/09/2008 - 12:23
Hi again and thanks in advance!!!!
is simple....The error is imposible to access by web browser
