Subnet help
Answered Question
Sep 9th, 2008
I have the following /16 172.31.0.0/16 that I'm trying to create an access list for. I'd like to allow 172.31.240.0/24 but deny all else, so I'm looking the best way to accomplish this with 2 acl lines.
Any help would be appreciated?
/rls
Correct Answer by Mark Yeates about 8 years 8 months ago
Robert,
Just a simple permit of the 172.31.240.0 subnet and deny the whole subnet will be sufficient.
permit ip 172.31.240.0 0.0.0.255
deny ip 172.31.0.0 0.0.255.255
HTH,
Mark
Overall Rating: 5 (3 ratings)
Correct Answer
Mark Yeates Tue, 09/09/2008 - 12:00
  • Gold, 750 points or more
Robert,
HTH,
Mark
rsamuel708 Tue, 09/09/2008 - 12:15
Thanks for the quick answer. Guess I was over-thinking the obvious!
/rls
Mark Yeates Tue, 09/09/2008 - 12:18
Glad I was able to help!
Good Luck,
Mark
singhsaju Tue, 09/09/2008 - 12:05
  • Silver, 250 points or more
The access list if you want to allow ip traffic sourced from 172.31.240.0/24 only as following :
access-list 100 permit ip 172.31.240.0 0.0.0.255 any
access-list 100 deny ip any any
Basically you need only one permit statement because there is implicit deny at the end of access-list.
Saju
Pls rate if it helps
