PIX501 Syslog everything
Sep 9th, 2008
Hey all, I am tring to syslog all connections from a pix501 to a linux server, I see lots of connections and denys etc... but for some reason I am not seeing everything.
I can test by doing a telnet to a random port to a server behind the firewall from my home pc, and I do not see it in the syslogs.
I can ping through the firewall and do not see that go through in the logs either.
I am running version 6.3(5)
My logging config is below
logging on
logging trap debugging
logging host inside neteng
(neteng is the linux syslog server and should be using local4)
I have tried to set all the firewall rules to syslog debugging also, and that does not seem to work.
Any suggestions to make this pix firewall just log EVERY CONNECTION?
Overall Rating: 5 (1 ratings)
suschoud Tue, 09/09/2008 - 12:14
I am very sure that you missed those connections in the syslogs.The level of logging setup is debugging and that's the highest on f/w.It includes all the lower level syslogs too.
Try :
logg mon 7
logg on
and see if on a telnet session to f/w,you see all those connections.If you do,then there is an issue with ur syslog server.
Sushil
jsdeprey Tue, 09/09/2008 - 13:00
It must be something on the setting of my syslog server, I new to setting that up.
But I have tried both
local4.* /var/log/pix.log
*.* /var/log/pix.log
The second, to my understanding should send all logs to that file.
Ill try to find some linux sys log server help, something is wrong
