Client users dialing 911 accidentally we think
Sep 9th, 2008
I have a client that is dialing 911 from there facility. I need to track down who it is or if it is a misconfiguration somewhere. What is the quickest way to put my finder on the caller? I don't have an exact time just a date during a specific week.
Looking at CDR's but there is 340 pages of detail under the call detail user report.
Any ideas?
Jaime Valencia Tue, 09/09/2008 - 16:14
  • Cisco Employee,
  • Hall of Fame,
    2011
unfortunately it's either CDR or a CUCM trace and i can tell for sure it's going to be over 340 pages of traces for the same amount of calls
with a timeframe best bet is CUCM trace, without it CDR and if enabled then look into CUCM traces
java
if this helps, please rate
TODD BERGMAN Tue, 09/09/2008 - 17:08
I went through the traces and nothing for that day. I downloaded the trace file for sept 6 and opened with wordpad and did not find any 911 or 9911 calls. How should I setup my trace configuration to capture this.
Do traces capture hangups? I would suspect traces would capture any dialed digits.
Jaime Valencia Wed, 09/10/2008 - 06:44
  • Cisco Employee,
  • Hall of Fame,
    2011
you need to enable them at detailed level using default settings to capture this, traces do capture hangups and from which side they came
java
