How many VRF's can be configured on a 6500 Sup720-3B?
vdadlaney
Hi All,
Are there any guidelines on the number of VRF's that can be configured on a particular platform and what is the impact of running a BGP context per VRF.
In particular I am looking to get information on the Cat 6K platform and the following questions
Is there a limitation on the number of VRF's that can be configured on a 6500 Sup720-3B?
2. If there is a BGP context(Only one AS but a separate neighbor)per VRF and say there are about 110 vrf's does this mean that there are a 110 BGP processes since every vrf has its own routing context/process?
What is the impact of the above on the Cat 6K Sup720-3B?
Thanks for your help.
7 Replies 7
Reza Sharifi
The total number of VRFs that are supported by Sup-720-3B and any other Sup is 1024.
see below link:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/product_data_sheet09186a0080159856_ps2797_Products_Data_Sheet.html
Reza
vrf on 6500 SUB720-3B: maximum 1024
http://www.cisco.com/en/US/prod/collateral/routers/ps368/product_data_sheet0900aecd8057f3b6.html
Ther will be only one BGP process (show process) if I understand correct
Also be aware of maximum number of routes: SUP720-3B: 256000. IPv4 192k standard, needs to be reconfigured to be used up to 236k. Cannot be used with full BGP table
Hi Reza and John,
Thank you so much for responding to my query. The way I understood it was
that for every VRF the BGP context will be treated as a separate process
even though its actually under the same global router bgp process. Is there
a limitation on the number of BGP contexts. I would assume that it would
match the number of VRF's which as both of you directed me to is 1024. That
would be perfect however just want to confirm that the Sup720-3B would be
able to handle approx 200 contexts and neighbors. The number might be a lot
less. The routes received from each of these neighbors won't be an issue at
all. Thanks
I am sure you are ging to be Ok with 200 VRFs.
maximum 1024 VRFs is not a bad number, but that is an area Cisco always has been limited compare to other venders like Juniper.
The Juniper MX960 supports up to 100,000 VRFs
Reza
Hi Reza,
Thank you for your response. Could you please confirm if there is a limitation on how many vrf eBGP neighbors can be configured. I plan on doing 1 per vrf hence it would come upto a total 200 eBGP neighbors. Is every vrf eBGP process treated as a independant process even though it is under the same global BGP process. Thx
Can someone please help? Thx
They are not independent processes since BGP is global and has one daemon. The only limitation would be the number of routes per VRF, so if you have Sup720-3B, that can handle a maximum of 256000, so if you have 2 vrfs with 128000 routes, then that is all the vrfs you can have, but if you have 200 vrfs with 100 routes in each, then I don't see any problem here. Also the type box with the amount of memory can affect the processing time.
Reza
