shane.kearney Tue, 09/09/2008 - 15:31
this question is from the icnd 2 book but i think the answer is wrong!!!
Francois Tallet Tue, 09/09/2008 - 16:02
  • Gold, 750 points or more
Assuming there is no trick like 0200 being octal vs 200 decimal;-) I would vote for 200:0200.1111.1111
Francois
shane.kearney Wed, 09/10/2008 - 02:00
Am I wrong to think the bridge IDs can only be in multiples of 4096?
by the way you are correct and i was wrong
Giuseppe Larosa Wed, 09/10/2008 - 02:08
  • Hall of Fame,
    Founding Member
Hello Shane,
bridge IDs can only be in multiples of 4096 if using extended system-id otherwise they can be any value between 0 and 65535.
Hope to help
Giuseppe
shane.kearney Wed, 09/10/2008 - 02:19
Last Question,
How do you know if the extended System is used or not?
Thanks for all the help.
Giuseppe Larosa Wed, 09/10/2008 - 05:12
  • Hall of Fame,
    Founding Member
Hello Shane,
two ways
a) from configuration
b) do sh spanning-tree vlan 1
and
sh spanning-tree vlan x
if using extended id:
bridge priority in vlan x will be:
base pri + x
if not using extended id
bridge pri in vlan x = bridge pri in vlan 1
but MAC address differ
(the extended id feature is also called mac address reduction for this reason)
Hope to help
Giuseppe
Francois Tallet Wed, 09/10/2008 - 08:51
Note that even with extended sysid, the priority will end up within the range 0-65535. Sure, you can only configure the higher 4 bits of the priority (by increment of 4096 indeed), but as you eventually add the vlan number to this configured priority, you end up with a figure that utilize the whole 64k range.
Francois
