IP Communicator 2.1.4 with TLS on CME
Sep 9th, 2008
I have configured a CME with TLS and the hardware IP Phones have downloaded the CTL and work with a security mode of authenticated without issue.
However, the IP Communicators just load up and say:
Registration Rejected:Max Phones Reached
If I set the device-security-mode to none again on the ephone for the CIPC it works again.
Any ideas?
Overall Rating: 4 (1 ratings)
Nicholas Poole Fri, 02/13/2009 - 02:58
No solution found so far, I have even moved to IPC7.0.1.0 and still the same. If you read the new blurb it says:
"Security Features
• Authentication: Transport Layer Security (TLS)-based mutual authentication is provided using certificates with Certificate Authority Proxy Function (CAPF) and Locally Significant Certificate (LSC) X.509v3.
• Media encryption: Secure Real-Time Transport Protocol (SRTP) for voice traffic with Advanced Encryption Standard 128 (AES-128) encryption is offered when using Cisco Unified Communications Manager Version 6.1.3 or later. Video encryption with Cisco Unified Video Advantage is not supported.
Network Interoperability
• Cisco Unified Video Advantage 2.1 or later to enable video telephony
• Cisco Unified Communications Manager 4.3
• Cisco Unified Communications Manager 6.0, 6.1, and 7.0 when using Cisco IP Communicator with SIP call-control protocol; Version 6.1.3 or later is recommended
• Cisco Unified Communications Manager Express 4.1 (nonsecured SCCP only)
• Cisco Unified Survivable Remote Site Telephony 4.1 or 4.3 (nonsecured SCCP only)
• Cisco VPN Client 5.0.01.0600 or later"
so i guess it not supported but they could be a little clearer, for post CME 4.1 users
