Unity Message button goes directly to Directory Handler
Sep 9th, 2008
Happened all of sudden today. RNA and busy goes to the subscriber mailbox but dialing the VM pilot or pressing the message button brings you to spell by name which is the directory handler. ANy ideas?
Chris Deren Tue, 09/09/2008 - 16:01
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
make sure there are not new "direct tranfer rules" defined on Unity pointing the the handler.
Chris
Jaime Valencia Tue, 09/09/2008 - 16:05
  • Cisco Employee,
  • Hall of Fame,
    2011
most probably someone was playing around with the call routing rules for direct calls and changed them so the one that sends you to the directory handler is above the sign in rule
java
if this helps, please rate
