Difference
Answered Question
Sep 9th, 2008
Hi All,
What exactly is the difference between CTI ports & CTI Route points?
regds,
aman
Correct Answer by Chris Deren about 8 years 5 months ago
Aman,
Think about a IPCC solution, people dial the cti route point to access an application, cti port is what answers the call and provides treamtment, basically a virtual phone that connects to the calling device (IP session between the 2).
HTH,
Chris
Overall Rating: 5 (1 ratings)
Marwan ALshawi Tue, 09/09/2008 - 21:13
hi there
The CTI port is actually a virtual device that allows you to create a virtual line
while with CTI route point u can use it as virtual phone to forward calls to send to voice mail, CRM and so on ..
if helpful Rate
Correct Answer
Chris Deren Wed, 09/10/2008 - 06:32
Aman,
HTH,
Chris
Googi1974 Mon, 12/29/2008 - 14:30
Hello Chris,
I ran across your post as I wanted to pose the same question. So if I have a remote user, who does not use IPC or even our Unity vmail, and we simply forward her company number to her home phone -- the cti port is the fitting solution here? Thanks in advance, Kelly.
Jaime Valencia Mon, 12/29/2008 - 14:35
a CTI RP with CFA to the external number or a translation pattern work on that scenario
java
if this helps, please rate
Googi1974 Mon, 12/29/2008 - 14:39
I appreciate your reply. Could I bother you to go into why choose the route point over just creating the cti port/phone and CFA to external as well. I'm still not sure as to why use one over the other. -Kelly
Jaime Valencia Mon, 12/29/2008 - 14:50
CTI ports are for 1st hand control, meaning they will take calls for another app, CUE, UCCX, UCCE, ETC.
CTI route points are merely routing as the name implies
java
